Originally Posted by san rensho
Water pump. The plastic impeller broke up into many fragments so try to account for all the broken pieces to make sure no little bits got into the tiny coolant passages in the head which can lead to localized overheating and cracking of the head.
san rensho, you're on point. just got a call from the mechanic and he said it was the pump. He recommends oem only on this part because they're weak to begin with. Cost difference seems to be about $120 between oem and aftermarket. Is it worth saving $120 for aftermaket? He also recommended a new belt for $45.
Although it's a repair, I'm just glad it wasn't anything major.
