Thread: !8 Inch Wheels
Old 06-19-2011, 05:26 AM   #7
Johnny Danger
Johnny Danger's Avatar
Originally Posted by redeye280z
I got the rims today they are 8inch wide 57mm offset for the front and the back are 9 inch 43 offset will these fit on a 2000 boxster S without having to use spacers?
The front offset is quite high, I would add at least a 10 mm spacer in order to move the wheel out a bit . As far as the rears are concerned, they'll fit ok . However, you probably won't be happy with the look or stance they produce . So, I would add a 10 mm spacer as well .
