Originally Posted by Brucelee
If you have a RMS leak you will know it. It will drop straight down and should not be connected to smoking like you described in any way. The oil will be on your garage floor.
If that smoke is white-ish, I would say you have a breach in the coolant to combustion chamber. This would indicate a head gasket I believe.
If the smoke is black, then your breach is more serious, oil to the combustion chamber.
Time for a service dept visit.
Thanks for the info on the RMS. That helps isolate it for me.
I'm going to do some more diagnostics before going to a service dept. I'm willing to do the head gasket and most other things myself. The only thing I won't DIY is inside the chamber (valves, pistons, etc.) because I don't have all of the special tools and they're pretty pricey.
