Old 06-16-2011, 08:39 PM   #4
99 Boxcutter
Goth Popper
99 Boxcutter's Avatar
I heard that wasn't possible from the Porsche dealer. They said the electrical would all have to be rewired. But I am curious if the body panels will all transplant.
I know they updated the Boxster in 2000 and again in 03- but I don't know if that was all under the hood.
Originally Posted by jhandy
actually 99-04 uses the same stuff.
find one that has a blown motor. You may find that you can just remove your motor and put it into a new body. Much cheaper and faster.
if you go that route, check concerns with dme and E gas and such, but i think that it can all be worked out easier than you think.
i have seen rollers go from 4K to 9K. mostly on ebay.
www.appleneworleans.com
99 Boxcutter is offline   Reply With Quote
