actually 99-04 uses the same stuff.
find one that has a blown motor. You may find that you can just remove your motor and put it into a new body. Much cheaper and faster.
if you go that route, check concerns with dme and E gas and such, but i think that it can all be worked out easier than you think.
i have seen rollers go from 4K to 9K. mostly on ebay.
2002 S
