			I've got one of the Porsche wall mounts.  It works well, though I had a problem with the holes that the spinock go into.  I had to modify them so they would work right.  I would not recommend that solution unless it is in a place where it will not get bumped.  The aluminum used for the mount is very thin and the first time I mounted it the top pulled right out (bending the aluminum).  I am going to put a strap on my wall as a backup in case it ever pulls out again, since it is on the wall above the hood of my Firehawk.  Don't want it falling on that.
 It's also a PITA to get the top onto the mount.  My wife and I put it up there, and it's tricky.
