Old 06-12-2011, 07:22 AM   #4
Gilles
Originally Posted by JTP
Did you check the oil pressure sending unit?
The oil pressure sending unit is new, since the connectors got broken during engine installation we may have cross connected them.
However, I believe that this will only keep the oil pressure light on, and we confirmed that we didn't have any pressure at all, through the inspection plugs at the head and also when we removed the oil filter it was bone dry... :-(
Could a malfunctioning Oil Pressure relief valve? like mentioned on the previous post (thanks..!) be the cause to keep the oil from reaching the filter?
Is the oil pressure relief and the oil pressure sending unit the same component?
Thanks in advance for your comments
