Really? Just take it to an A/C shop and have it done right. First off, if the system is lacking refrigerant, it went somewhere, so first you need to find the source of the leak. Then, you need to pull a good vacuum down on the system. Then, you must charge it with the correct amount of refrigerant, with the appropriate percentage of oil to properly lubricant the compressor.
Boxster S
