18. Secure the connector end of the cable to the box. Take the cable from both speakers and create a loom using the insulation tape.
19. Wire up the connector. The other end of the connector is wired to the head unit. I didn't take any pictures here but you can easily run the cable from the box to the stereo down the channel on the passenger side. You run it down the side of the car, along the bottom of where the glove box is and then into the stereo space.
20. Final picture of everything in place. Even though the speaker are pointing out you still get the desired effect of having balanced sound. If you want to hide the speaker completely. Use the facia (that you kept earlier) and surface it with speaker cloth. Then "pop" it back into the same location.
That's it. Sorry if instructions are vague. If you need pics of detail or where I ran the cable please ask!
Hope this helps people out. Just my way of giving something back after all the great advice I've been given.
2001 Porsche Boxster 2.7 L
