3. Remove the box. Throw the large part away, keep the facia.
4. Indentify the groove in the plastic. This is where the speaker panel will mount.
5. Groove in detail
6. Take two copies of the template (or one flipped). Use some backing board (5mm) and cut two panels out using a jigsaw.
7. Cut out the speaker holes ensuring a tight fit. Dry fit to make sure hole is right size. Remember you can take material away but you can't add it back!
(part 3 up next)
2001 Porsche Boxster 2.7 L
