Old 06-09-2011, 12:32 PM   #1
fredpayne
fredpayne's Avatar
Originally Posted by Peter Reed
I bought the Gentex K21 Auto-Dimming reaar veiw mirror with compass and temp and the mirror wire cover from Autoanything.com for $210.
This is a great mirror with the Boxster and the outside temp and compass are a big help.
Only issue is finding a path to run the temperature probe up to the lower grills on the bumper. Had to remove the headlights, front trunk liner, etc to find a path for the cable. Had to feed it through a few rubber grommets in the firewall. It can be done!!!
Also, had to use a conventional mirror mount - just mounted it to the right of the Porsche puck. Top of the puck mount should be at least 2" below the plastic headliner.
Thanks Peter, I purchased one of these.
2003 Boxster S - Orient Red
2010 Toyota RAV4
Past Toys
2000 Boxster - Ocean Blue
1994 Toyota Supra 320HP
1987 Porsche 944S
1983 Porsche 911 Carrera
1980 Porsche 911 SC
1976 Trans Am 455 Cu.In.
1962 Corvette Convertible
1957 Pontiac 2DR HT 421 Cu.In.
fredpayne is offline   Reply With Quote
