Enjoy! Just a heads up... RA-1s work best with -3 camber and you will be lucky to get -.7 in front with stock struts. With that setup you will be murdering the outside edges of your tires. Adding a M030 rear sway will allow the car to rotate more easily and take some of the push out of the front tires.
