First off, thanks again for all of your help, but I have another question. I contacted the ebay seller about the 10mm spacers, he wanted me to measure the hub on which the factory wheels sits on the rear of my boxster. I measured and found them to be 12mm long, so he told me that I couldn't use any spacer shorter than a 15mm spacer without causing problems. I don't think I want to run a 15mm spacer because the the wheel is a et52 which would put me at a +37 after spacers mounted, right? Won't that put the wheels out pass the fenders? Any suggestions? I'm just confused as from reading through all of these posts it looks like many people are using 5mm or 7mm spacers on their rears. Should I just look at another source for the spacers? Thanks again.
97 Boxster
18" BSA Wheels
Clear Side Marker Lights
2003 model taillights
