Originally Posted by peterbrown77
Ummm - okay.
I've read the manual but I have a question (well a million, really but one for now).
I brought it home put it in the garage, set the parking brake, everything is off, key is out of the ignition, the top is down. However, when I open the driver's door, the chime starts dinging. Why?
TIA
At 60K, my 2¢ guess would be that you need a new ignition switch. The car thinks the key is still in the switch when you open the door.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
