Old 06-03-2011, 01:48 PM   #3
jhandy
No it does not do the 1/4 inch drop when
Using the inside or outside handle. Otherwise
It works fine. Up and down smooth with no play.
I am thinking that there is some kind of switch in the
door mechanism that tells the window that the handle
is in use.
Looking at the parts diagram, there is a switch in the outside handle
But is there one for the inside handle?
It would have to be a part that is operated by both handles.
I can just take it apart and I am sure the broken part will be obvious by all the pieces I heard fall.
If possible I wanted to order the repair part before I take apart the door because this is my daily driver and I don't want to drive around with the door panel off while waiting a week for the parts to come in.
2002 S
jhandy is offline   Reply With Quote
