Dont waste your time reading CELs.
chances are with the failure you are describing, you'll be throwing every CEL in the book.
Think more fundamentally: you car overheated. What's the worst case scenario? over pressure in one of the water passages at or near the cylinders and a cracked case leaking water into the combustion chamber. Pull your plugs. Are they wet?
Why did your car overheat? Bad thermostat? Running low on coolant? Check your coolant. IF it isn't there, then where is it? Maybe it's In your cylinders... But hopefully not.
