Originally Posted by bobdogwv
I am still wondering what size spacer I should get. I'm afraid the 7mm won't give me enough clearance over say a 10 or 12, yet I don't want the outside lip sticking to far beyond the fender. Has anyone had any problems with something this size rubbing on the outside? Johnny Danger, what size rims are you running on the rear? What is the ET? You mentioned running 275's on the rear, is that a 30 series or a 35? Once again guys, thanks for your help!
I have the following wheel fitment :
front: 19 x 8 +31 et 235/35/18
rear: 19 x 10 +31 et 275/30/19
Keep in mind, my set-up is very aggressive, and my vehicle has been lowered via adjustable coilovers . However, prior to this, I experimented with different wheel
sets, along with different suspension configurations. With that said, I can tell you from experience, if you're using a 10 inch rear wheel, I recommend targeting an offset between +40 to 45 . As far as the fronts are concerned , depending on the look or stance that you're trying to achieve, with an 8 inch wheel I would recommend offsets ranging from +38 to 40 or so .
