Old 06-01-2011, 05:37 AM   #2
Johnny Danger
Johnny Danger's Avatar
Originally Posted by bobdogwv
I must have had a brain fart, I looked at the boxes again, and the fronts are 18X8's with a ET 48. I don't think that I will have to put spacers on the front with those. Thanks for the help Johnny D!
If they're 18x8 +48 then you're good. However, ultimately you may find that the fronts look quite a bit "in" as compared to the rears . In which case, adding a 7 - 10 mm spacer will bring them out nicely .
JD
p.s. Try contacting this member, Allen K. Littlefield . He recently found an excellent source for spacers at very reasonable prices.
