Originally Posted by bobdogwv
So a 7mm spacer should do the trick, any recommendations of a brand of spacer? Any thoughts on tire size as well, I have read that some tires, although being the same size, may have a few mm's in difference. And one more question, do you think the front will be ok? Thanks for the response JDanger.
Depending on the brand, sidewall angle and shape can vary between tires . In any case, I've found the following sizes to be an excellent choice with regard to fitment and performance : front/235 , rear/275 . Also, if in fact the fronts are 9 inches wide, you're going to have clearance issues as well . You'll need to lower the offset in order to gain enough inner clearance . However, the trade off will be, that the wheel may then protrude too far outward - causing clearance problems with the fender lip . A 9 inch wheel is not a good choice to use up front on a 986 boxster . Regardless of what spacer you use, I don't think that it will fit .
