Old 05-31-2011, 07:24 PM   #2
Jager
Jager's Avatar
Originally Posted by timothy
I swap brake pads quite often (track and street); here's the method that works for me. Quite a few use a c-clamp but I've never been a big fan of that approach.
1. Put the old pads back in the caliper
2. Position a set of slip joint pliers in the space above the rotor and between the pads so the jaws touch the tab at the top of each pad.
3. Pull apart on the pliers handles. As the jaws separate they push outward on the pads and pistons are forced back into the calipers.
4. Remove the old pads and insert the new.
5. Reinstall retaining hardware
My method is very similar to Timothy's except I use this tool (pictured). Makes the job very easy, instead of pulling apart the handles I squeeze them together to separate the pads. I believe Sears carries a similar tool.
Jäger
300K Mile Club
