Old 05-31-2011, 04:57 PM   #3
WRGREENER
Wd40= Solvent
Originally Posted by insite
the nylon ball joint races are NOTORIOUS for this. there's a simple cure. cut a tiny hole in the ball joint boot & spray in some WD40. problem solved.
WD40 is a solvent not a lubricant. you need to lubricate not wash it away
WRGREENER is offline   Reply With Quote
