Old 08-25-2005, 09:13 PM   #1
eslai
Originally Posted by SD987
I notice a surprising number of stick drivers who don't let the engine wind down and push in the clutch as soon, or too early as they start braking/decelerating. Letting the engine wind down dramatically improves brake performance and wear by using engine compression to help slow the vehicle. I’m not talking about engine braking, I’m talking about coasting/slowing with a gear engaged; not in neutral.
Ah yeah, this is important--a lot of people coast around in neutral without realizing that this is dangerous. You can't get out of the way of someone if you're in neutral!
The above being said, I think the biggest culprit to poor clutch/transmission life is general technique. It amazes me that people can go their whole lives and be crappy shifters...you want to shift with consistency and maximize your performance.
This is key, really. You can't heel-toe, rev-match, or any of that effectively if you aren't consistent with it. I know a lot of guys that drive around like hotshots but half of the time, they screw up their shifts... No good.
eslai is offline   Reply With Quote
