Old 05-28-2011, 11:25 AM   #2
Flavor 987S
Ragg Topp
Use the Ragg Topp Cleaner. Use a quality, soft cleaning brush. I use a leather cleaning brush. Let dry for a couple days. If spots are not gone, rewash again. Let dry again a couple days. If spots gone, vacuum, tape roller, and vacuum again. Then apply 3-4 light coats of Ragg Topp Protectant. Each coat needs about 20-30 minutes dry time between coats. Spray a coat, then take a nice high quality paint brush, and brush into the fabric top. Let dry. Vacuum. Repeat.
A couple thin, cheap, plastic painters tarps come in handy. As does some 2 inch blue painters tape for masking off areas. Wipe the rear glass off after each coat. When completely done, give the rear window a good cleaning (1 part denatured alcohol to 2 parts distilled water, spray on window only cloth, wash window, polish dry with seperate towel).
My 2006 Cocoa top looks as good (even better) since the day she was born, even after 40,000 miles. And a few Concours wins.
As a tip, always carry a spray bottle of distilled water with your car. If you see a bird bomb, you car hit it with the spray bottle, and avoid issues later. Works on the top and paint.
If you have any questions or concerns, contact Rick at Ragg Topp at rick@wolfsteins.com. Good guy.
