Thread: Overactive horn
Old 05-28-2011, 03:58 AM   #5
vath2001
Pulling off the air bag and bracket is rather easy. The hard part was finding the t30 torx screw driver to unscrew it. You can't use the t30 bit on a changeable driver. The hole in the backside of the steering wheel is too small (at least for the set I had).
First thing is to disconnect the battery for about an hour before you start, to allow the air bag to loose its charge.
good luck.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
