Old 05-27-2011, 12:29 PM   #27
Gilles
Originally Posted by Jake Raby
The sprung center disc only helps with harmonics and frequencies that are sent upstream through the input shaft from the drivetrain. The sprung center disc does nothing to aid in the harmonics generated by the engine that cannot be absorbed by the second mass of the flywheel after it has been removed and replaced with a single mass.
Jake, can the loss of the dual mass flywheel be compensated with an UDP that has a harmonic balancer built into it? like the ones offered by RSS or ATI Racing..?
http://www.atiracing.com/products/dampers/damper_tech.htm your comments will be greatly appreciated.
Gilles, across the street from El Toro base...
