Old 05-27-2011, 07:17 AM   #11
pompous
First thing I would do is take it to somebody who specializes in piracies and hook it up to see if there are any transmission codes (I don't know if a bad tcm will throw codes or not) & to see if the ATF level is correct. Other than that (somebody correct me if I'm wrong) slipping points a lot of times to a torque converter problem, but may be as simple as low tranny fluid.
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
