Originally Posted by Jager
Why were you looking... Do you have an issue?
I have a cel that's coming up as code P0102 which pertains to a low voltage reading associated the maf sensor . This can involve a faulty wire or ground problem somewhere between the sensor and the DME . On the other hand, it could just be a bad sensor . However, it's important to first rule out a bad connection . On a hunch, I thought that I would consider the possibility of a blown fuse . Oh, well .
