Old 05-24-2011, 10:55 AM   #21
Bladecutter
Originally Posted by Jake Raby
The procedure for forcing an engine failure is to extract a perfectly good IMSR bearing from an engine and replace it with a bearing that is at stage II failure.
Then drive the car until the engine breaks... While my technology is employed to forecast the big moment..
I sacrifice good parts all the time and this won't be the first time I have blown up a 6,000+ dollar engine on purpose, for the sake of science and development.
Jake,
Are you planning on using an engine that a customer had in their car that you recently replaced with one of your engines, or are you building an engine from a randomly sourced core with parts you have on hand, or are you building and engine using perfect parts, and the failed IMS bearing will be the only faulty part in the entire engine?
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
