Old 05-23-2011, 05:53 PM   #2
blue2000s
Porscheectomy
The pads are constantly wearing down the rotors, so the thin layer from the old pads will soon wear off. Bedding helps to get the naked rotors coated with the pad material but after that, the rotors are constantly getting "bedded" as they wear thinner. If you just put on your new pads and run through the manufacturer's bedding process, you should be good to go.
