Old 05-23-2011, 05:03 PM   #1
jhandy
sanding my rotors?
I would like everyone's thought about sanding my rotors.
I have OEM pads on the car, and the brake light turned on today. It looks like the drivers side front is the culprit.
I wanted to replace the pads with pagid orange and I remember reading somewhere that if you change pad compounds you should turn or sand the rotors.
I cant turn them, they are drilled. Also I DO NOT want to sand them. I would love it if I could drop in the new pads and get to driving in 30 mins without taking everything off.
So what is the consensus? Sand or change and go?
Thanks,
James
2002 S
jhandy is offline   Reply With Quote
