It's hard to tell what's going on with the video audio. Was the engine warmed-up when you performed the test? The car will almost stall/die when the AOS diaphragm is bad and you open the oil fill cap.
Hopefully you don't have a bad AOS, maybe the sound you are hearing is just air flow through the throttle body??
Jager
