Old 05-21-2011, 02:36 PM   #1
newtothegame
under the high level rear brake light you will find a cut out inside the boot, on the other side of this in the engine compartment there is also a cut out, just behind the sound deadening next to the catch for the reef realease, its not perfectly lined up but i have just thredded the wire for my parking sensor buzzer through there, have then run it through the passanger side under the carpet and stuck it with 3m to the underside of the roll bar
newtothegame is offline   Reply With Quote
