Old 08-25-2005, 06:49 AM   #1
hdpt73
Finally solved the Check Engine light problem
Had a CE light problem
replaced air filter
checked for leaks in air intake
replace MAF
all did not work
I found a cracked ignition coil wire that plugs into the spark plug
replaced that and reset the cpu
No CE light so far
I checked with porsche service guy and he said at 60-80 thou miles these coil problems are popping up more so there's a suggestion.
hdpt73 is offline   Reply With Quote
