Old 05-18-2011, 12:11 PM   #1
enjoyurporsche
clicking clutch
i had the same issue with my '98.
i took it to my mechanic, all fluids were topped and clutch is not worn.
we took it for a road test, at that time, on an open road, he accelerated to about 4 gear with about 4.5 rpm speed. While doing so, he pressed/depressed the clutch several times. This seemed to relieve the clicking noise. I haven't had it since. Just get in there and press/depress the clutch several times...get some lube in there and loosen the housing up a bit might do the trick.
enjoyurporsche is offline   Reply With Quote
