Old 05-18-2011, 09:47 AM   #1
vonders
Had a repair list back as long as my arm..what now?
Hi
First post coming up..
I have just put by 97 Boxster in for a minor service having recently acquired it, this was mainly due to an oil leak found in the past week that was not there a few weeks back.
Have had a major list come back from the porsche dealer, below are the main ones, can you please advise on whether these costs look ok and also whether the work is essential?
Clearly the oil leak needs checking out..the leak on the ground was near the back centre of the car...obviously worried about the RMS
Prices in GBP
Engine
Engine leaking oil, Advise req Initial 1hr diag time to R+R engine covers, steam clean engine as best as possible &
try and identify origin of leaks & Report back on findings 104.40
this is the big one, is this an accident waiting to happen? what happens if bushes are completely gone?:
Steering & Susp
N/S/F, N/S/R & O/S/R Lower arm bushes split/separated (Labour inc Geo NB Additional time may be required to
remove siezed bolts due to vehicle age) - Req x3 Lower arms + Associated lock nuts 1314.47
Exhaust Cat section to muffler U-Bend clamps/sleeves corroded - Req Cut-off old & replace Clamp/Sleeve 128.88
- what does this mean in real terms?
Front, Rear transverse & L-Shaped undertrays broken 111.94
- probably not worth it?
Permanent fault codes stored in DME. Advise Investigation of faults as engine doesn't appear to be running right -
1hr Intial Diag 104.40
- according to dealer these are oxygen codes that need further investigation
Non-Porsche battery 260.00
- cheek!
vonders is offline   Reply With Quote
