How much higher do you want to go? It's common practice on Subarus to add a shim between the strut and the body to raise the rear of the car (saggy butt spacer). I think it would probably be pretty easy to get a pattern and have some spacers made for your car. But you want to make sure you still can get the strut threaded onto the body so that might limit the height you could go. Definitely less expensive than replacing suspension parts.
