Old 05-13-2011, 02:29 PM   #1
Jager
Jager's Avatar
Originally Posted by pk2
Hello All
I’m replacing a bum trans. at 40k and obviously want to replace necessary components while I have it cracked open. Barely drive it here in suburbia but when I do, I do kick it around a bit. Don’t need to go over board with racing stuff unless there’s an awful good reason and it’s cost effective for my use.
1-IMS Bearing; LN the only game in town?
2 Clutch (assuming worn 20% or more) what Brand for durability, casual use? Semi Performance?
3 Pressure plate; (why if there is no scoring/wear? Springs or something?) If good reason, brands?
4 Clutch release/throw-out bearing: (mine is shot) Sachs, INA, ??
5 Pilot bearing (is there one?) brand??
6 Gear oil; Symco(?) or….
7 Rear motor mounts?
Again, I’m not racing (but do hoarse around). Performance parts O.K. if not a big premium $$ (may autocross some day though). Just want to get it back on the road for the next 40k mi. (10 yrs.) without paying through the as_ for inferior parts
Regards, PK
PK,
I recommend you go with an IMS bearing brand that has some history.. Don't go cheap here.
Yes there is a pilot bearing, if you buy a new flywheel (I recommend) it should come with one.
My transmission mounts (rear motor mounts) were fine after 210,000 miles, you should not have a problem here. Have you replaced the front motor mount? Something to consider.
Jager
