Old 05-10-2011, 04:42 AM   #1
ekam
Variocam Plus has something to do with it as well.
"Porsche's more recent VarioCam Plus combines variable valve timing with two-stage lift on the intake side. The two-stage valve-lift function is performed by electro-hydraulically operated switchable tappets. Each of these 12 tappets consists of concentric lifters which can be locked together by means of a pin. The inner lifter is actuated by a small cam lobe, while the outer ring element is moved by a pair of larger-profile lobes. The timing of each valve is seamlessly adjusted by means of an electro-hydraulically operated rotary vane adjuster at the head of each intake camshaft."
http://en.wikipedia.org/wiki/VarioCam
