			I just got my 97 Boxster and the column will not telescope on it either.  I just bouht the 3-stalk switch and cruise module - when I have the wheel and switches off, is it easy to get some penetrant in there....or better yet... to remove it and clean/lube it properly?  Or do you have to pull the entire shaft out?thanks,
 Mark
						Reason: shafted by the non-telescoping shaft
