I've been dealing with a cel issue for the past few months while my vehicle has been in storage. The code that is coming up is P0102. Today, I removed and inspected the MAF sensor and observed that it wasn't dirty at all . Nevertheless, I thoroughly cleaned it just the same . Shorty after reinstalling it, and resetting the cel by removing the negative battery terminal ect... the cel came back on . Is it possible that the sensor could be bad despite the fact it didn't show any signs of contamination ? Any thoughts ?
JD
p.s. Prior to checking the MAF, I removed the air intake filter and thoroughly cleaned it .
Yes it could be a bad MAF. other thing beside the one you addressed is the plug might be loose? broken or shorted wire? DME could be bad but rare. Try leaving the battery cable off for a much longer time such as an hour then drive it and see if you get another light. the code is saying that the voltage is much lower than expected from the maf which is air flow.... try unpluging the maf and drive it if there is no difference you might have a bad maf .
