			Drawing from my memory of changing out my springs, how exactly can you take the bearing out without taking the whole thing apart?
 IE: How do you get the bearing out without removing the axle....How do you remove the axle without removing the hub/spindle.....How do you remove the hub/spindle without unhooking everything?
 Trying to learn tricks, because changing the springs was an easy job.....but it took me every bit of 4 hours per corner.
				__________________2002 S
