Originally Posted by xamfed
It is powered, so yes it can. You need to get high-level inputs to get the audio signal from.
Thanks for finding this, I may be getting this for my 987
I don't know enough about audio to know what exactly that means or how to get it. I've wired up radios before and helped install some subs with some friends but I don't know what all that would require. Getting it power and ground isn't an issue.
Jhandy- I dont think it would be an issue other than it might vibrate your dash some and I'm not sure how that would be right under an airbag? Might not be an issue though. Might need the help of others to chime in.
That place that sells those amps and other audio equipment is only like a 25 min drive from my house. I'd be half tempted to drive down there to check this stuff out a little more and see what they say.
