Old 05-01-2011, 04:18 PM   #31
jaykay
jaykay's Avatar
Originally Posted by tonycarreon
not a lot of info out there, so maybe someone else can chime in. from what i gather the "acceptable" deviation is +/- 6 degrees on each bank, no idea as to what is acceptable difference between 1 and 2. i am sure the pads are worn out seeing as the car is 10 years old and has 85k miles on it, no work has been done in regards to the timing system.
By pads do you mean chain tensioner pad wear giving more cam chain slop and loss of motion on cam shafts?
986 00S
