Old 05-01-2011, 07:51 AM   #30
tonycarreon
tonycarreon's Avatar
Originally Posted by Jager
More than 3 degrees difference between banks on deviation... Not sure what the specifications are for timing difference between banks are but you might want to take a close look at this. I'm sure performance is not optimal.
Jager
not a lot of info out there, so maybe someone else can chime in. from what i gather the "acceptable" deviation is +/- 6 degrees on each bank, no idea as to what is acceptable difference between 1 and 2. i am sure the pads are worn out seeing as the car is 10 years old and has 85k miles on it, no work has been done in regards to the timing system.
