If you only need to clear the code and nothing else you could just disconnect the battery. In fact that might be a good idea anyway for a MAF sensor issue because you want the car to discard all its previous fuel trim adaptation values. Sometimes clearing the code with a scanner will do it but disconnecting the battery is guaranteed to force the car to relearn.
