					Originally Posted by kcpaz
				Did you even read my post? I don't have wheels, I'm having wheels made. The offsets will be whatever I want. I'm using 17" wheels because I don't need a larger wheel for brake clearance and I want as little weight as possible. This is a race car, not a street car. The body is literally flared meaning custom fiberglass panels.
You state in your post that you will be "running 17x10" and 17x12" CCW Classics", nowhere do you mention that they're being made to order with selectable offsets . Therefore, the presumption is that these wheels have already been produced. With that said, I can't imagine being able to clear the perch on a set of aftermarket of coilovers with anything greater than a + 10 or 11 et on a rear wheel that wide, and +31 or so up front .
