Old 04-30-2011, 02:29 PM   #2
JFP in PA
You have a large vacuum leak in the EVAP system (behind the passenger's side wheel well liner). If you are certain it is not the gas cap (check the o ring seal on the cap to be sure) as you said it happened just after refueling. System consists of a charcoal canister, several valves and vacuum lines, anyone of which can be the culprit. It is not a MAF related issue.
