Old 04-30-2011, 11:27 AM   #2
JFP in PA
Not uncommon. Most likely either the o-ring is pinched or cut, but the canister may not be tightened enough. I’d check to see the canister is tight first, if it is, then I’d plan on pulling the canister and putting a new o-ring and filter in and then topping up the oil level.
