Old 04-29-2011, 09:25 AM   #13
BYprodriver
BYprodriver's Avatar
Originally Posted by nsbst2t
Just went out and cranked it up again. No smoke at all at first. So
I let it idle. after 9 minutes it started smoking but not like it was before.
Your #2 cylinder sparkplug is probably oil fouled. Passenger side middle cyl. check it, replace if needed & check #1 & #3 if #2 was bad then get on the hwy & burn out the rest of the oil. Just be aware if the smoke gets worse shut off the engine. The engine can Hydrolock if enough oil gets in a cylinder & bend a connecting rod, but I think you are safe unless the AOS starts dumping oil again.
