Thread: Ignition switch
Old 08-22-2005, 05:52 AM   #6
limoncello
Got back from vacation and the switch worked normally (typical of electrical make-or-break). Got under the dash, saw the switch, didn't look too bad. Removed the vent tube no problem. Now if I had short arms with two elbows in each arm I could reach it.
Can you remove the lower dash cover? How hard? This would really open up access to the switch.
Wonder what the little plastic slot on the lower dash cover is for? Never noticed it...
limoncello is offline   Reply With Quote
